Solid Axle Swap (SAS)
Upgrade your 1985-1995 Nissan Pathfinder WD21 with solid axle swap (SAS) parts and components for a stronger, more capable off-road suspension setup. Converting from the factory independent front suspension to a solid front axle is a major modification commonly used on dedicated trail rigs, rock crawlers, and heavily modified 4x4 builds.
Nissan Pathfinder WD21 solid axle swap components can include suspension brackets, steering parts, spring mounts, link components, axle mounting hardware, and other fabrication parts needed to complete a straight axle conversion. The exact parts required will depend on the axle, suspension design, steering setup, and overall build configuration.
A properly designed solid axle swap can provide increased articulation, improved durability, greater suspension travel, and better capability with larger tires in demanding off-road terrain.
Shop solid axle swap kits and SAS components for 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, and 1995 Nissan Pathfinder WD21 models below.
Validate your login
